hladam info o Malaguti f18 125ccm
Nazdar skutristi , Potrebujem nejake info o tomto skutri kedze si ho chcem kupit a nic som o nom nenasiel , Dakujem za odpovede
### tema premenovana a presunuta do Volnej diskusie... kedze to nie je recenzia - THeBaNDiT
Re: Malaguti f18 125ccm
hmm... hladanie na fore nenaslo ziadnu zmienku o F18, ma ho tu vobec niekto?
Re: hladam info o Malaguti f18 125ccm
ked si o nom nic nenasiel tak asi neexistuje a nechces si ho kupit.
- Martin_Atlantic
- Dátum registrácie: Ut Nov 15, 2011 10:59 pm
- Skúter: Aprilia Atlantic
mino221:
no...ty asi skor zhanas neaky nazor od majitelov a skusenosti co? toto su len technicke udaje. ale tak snad aspon nieco pomoze.
General information
Model: Malaguti F18 Warrior 125
Rok: 2005
Kategoria: Scooter
Hodnotenie: 64.9 out of 100.
Objem: 125.00 ccm
Typ motora: Jednovalec 4-Takt
Vykon: 10.59 HP (7.7 kW)) @ 8000 RPM
Krutiaci moment: 9.80 Nm @ 6500 RPM
Kompresny pomer: 10.0:1
Bore x stroke: 52.4 x 57.8 mm (2.1 x 2.3 inches)
Palivovy system: Karburator
Zapalovanie: Elektronicke
Chladenie: Kvapalina
Prevodovka: Remen
Spojka: Automaticka odstrediva
Frame type: High resistance braced tubular steel frame
Front suspension: By telescopic hydraulic fork
Front suspension travel: 33 mm (1.3 inches)
Rear suspension: By swinging engine and 2 hydraulic shock absorbers
Front tyre dimensions: 110/70-13
Rear tyre dimensions: 130/60-13
Front brakes: Single disc
Front brakes diameter: 200 mm (7.9 inches)
Rear brakes: Single disc
Rear brakes diameter: 200 mm (7.9 inches)
Physical measures and capacities
Dry weight: 118.0 kg (260.1 pounds)
Power/weight ratio: 0.0897 HP/kg
Seat height: 800 mm (31.5 inches) If adjustable, lowest setting.
Overall height: 1,170 mm (46.1 inches)
Overall length: 1,870 mm (73.6 inches)
Overall width: 755 mm (29.7 inches)
Wheelbase: 1,320 mm (52.0 inches)
Fuel capacity: 8.00 litres (2.11 gallons)
Other specifications
Starter: Electric & kick
Tie dolezite som prelozil: Davidian.. diky: Martin_Atlantic
General information
Rok: 2005
Kategoria: Scooter
Objem: 125.00 ccm
Prevodovka: Remen
- rspeed
... starsie verzie boli 2T ....
http://malaguti-f-18.autobazar.eu/125-id2110988.html Konkretne sa jedna o tento skuter, Ano potreboval by som nejake nazory od majitelov ale ako vidim tento skuter asi nikto nema tu na fore , No nic pojdem ho asi pozriet a uvidi sa
Byvam na lazoch , mal som uz skuter aj predtym zatial nemol ziadny problem , len som potreboval nejake info o tom skutri co to je zac , lebo predtym som mal leonardo 150tku a neosvedcilo sa to velmy , viac som sa v tom hrabal ako to islo takze tak
